I live in a mobile home and recently changed the switches in living room 2 double gang boxes (they are weird enclosed ones with metal slats that pinch the wires).
One wire got loose, so the switch to an outlet wasn’t working. After replacing the first set of 2 switches, with regular switches, Lights to the fan started flickering.
I thought I needed to complete changing out the other set of 2 switches ( they are side by side btw) because something was wrong. Lights flickered but wasn’t too crazy.
A month went by and I recently had time to replace those pending switches and when I did, all hell broke loose. The lights and all outlets to the living room started flickering and the fridge, the kitchen island outlets, some lights in bedrooms flicker too and vent hood started flickering,,started turning off for a Few seconds, for no apparent reason.
Sometimes only the appliances are on and sometimes when the fridge starts up it starts flickering and powering off completely or just fainting enough to reset appliances. (Worried my fridge will die with unstable current)
& call me crazy but(I did notice that when airplanes go by or we walk in different areas - haven’t pin pointed exactly where- and the house moves sometimes the whole light show starts)
The electrician came to check the wiring on the switches I changed, everything was good, he did tighten one that had gotten loose. Problems persisted. he changed the breakers to the problem areas and did see one breaker was not completely in, but new breaker is installed nicely and rest of breakers as well. Problems persisted not as bad but still flickering.
Changed out outlet for fridge ( the weird old style as well- found some wires were loose) problem diminished in frequency but still when it gets crazy it starts with flickering, on-off power and or fainting but powering fully again.
Called the park and they said meter outs looks Good but I don’t know what else to check. Electrician says he’s going to go under the house to see if something is up with the cables underneath, But wondering what you think?
I read in other posts maybe the meter and to call Power co but the Park says it only comes if we have no power at all
Anyone with experience please help or if it sounds familiar can help!! All I want for Christmas is steady electric power at home…
Pictures are from switch taken out of the wall. I replaced it with regular ones that tighten with screws.
Power to house is 120v
Things stabilized the day after electrician came. I do remember him pulling the power cable from the switch box. He said in case something was making a bad contact. But it still made the flickering. It was overnight it went back to normal.
It’s been 10 days since I’ve had issues with the lights and outlets flickering. It had stopped as I mentioned above, but today it started up again 😖. Could it be a meter problem? All connections were checked by electrician and were corrected. I read in other posts similar to mine about a neutral problem? Any help please. I’m calling The Poco January 2nd since we are in New Year’s Day!!! (Typing at 3:45 am …)
