I just bought a lighting fixture (a LED light) that has a power and a neutral line, but no ground. Is this typical for newer low power lighting, or is this lighting fixture just trash?
There are no certification markings on the box. https://www.amazon.com/dp/B0C3D4TH2J
    When I try to look at the picture you haven't provided, there's no way to tell. Does it have a marking from UL, ETL, or another Nationally Recognized Testing Laboratory? Probably good. Is the only offical-looking mark on it CE - probably bad. Is the exposed housing metal? Probably bad. Is the exposed housing plastic or otherwise non-conductive (glass, etc.) - then it might just have a NRTL marking and not need a ground wire.
    Commented Dec 6, 2023 at 23:37
  • Is fixture plastic? Not sure of the percentages, but would guess at least half or more light fixtures do not use ground.
    It's pretty common not to have ground. I've seen fixtures with a ground wire that's connected to nothing at all inside the fixture "just so they have one". You need a ground if the fixture is metal, otherwise there's nothing to connect the ground to.
    – Ariel
    Commented Dec 7, 2023 at 3:10
  • if the packaging is marked with a square inside a square mark, it's double-insulated, and thus safe to use w/o grounding. Some folks mistake the symbol for a "square-D" mark, and some folks misunderstand square-D for certification (it's a company).
    – dandavis
    Commented Dec 7, 2023 at 23:00
