I was working on the house last year and asked about this project previously. I never got around to tackling the living room as other rooms had priority. But now I am returning to this.
Previous post here:
How to raise my living room floor by 3 inches?
Started a new thread as it's been so long. Reading comments there again, I see that people had asked for more info, which I'm providing. Let me know if any additional info would help.
House built in 1975. Room is about 16' square built on 2x10 joists spaced at 16". House and room are structurally very solid but the existing subfloor is "wavy" - specifically due to some joists being up to 3/4" lower than others. None of the joists are at the same height. By my determination, it was just built that way. Floor was originally carpeted (on top of 5/8" particleboard that I removed) and you couldn't tell it wasn't flat. The plywood subfloor is 5/8" and is nailed (was existing) and screwed (I added) down to joists. I can access the floor from below (prev post was incorrect - basement is finished but not below living room). The joists have wood cross-bracing.
The hallway had been tiled in marble by a previous owner. This raised the floor by nearly two inches. Obviously it was already a big step as there is now a 9.5" step down from hallway level to living room subfloor level. I am putting down LVP atop a new 5/8" AC plywood underlayment - both of which I already have as I'm doing same in 3 bedrooms. In bedrooms, I only had to raise the floor by 1.5", which I did with strips of 3/4" plywood below new 5/8" underlayment.
There are four approaches that I've considered or had suggested to me. Looking for feedback - including pros and cons.
2x4s on edges, orthogonal to joists, every 8", scribed and cut make floor flat
2x4s on edges, parallel to joists (one on top and one halfway), scribed and cut make floor flat
2x4s on sides, orthogonal to joists, and shim to flatten
cut with circular saw 1.6" wide channels, orthogonal to joists, for 2x4s on edges to fit into, trimming joists at intersections as needed to make level
Regardless how how I shim up the new underlayment, I plan to have supports under the new underlayment at no more than 8" spacing.
I already have LOTS of shims cut of various thicknesses of plywood from 1/4" to 3/4" for use in approach #3. I already have the AC plywood and LVP.
Someone in previous post had suggested "sister 2x8s beside the existing joists". I don't think that would make sense. Too much work - including removing cross-braces from joists.
