I have a garage that is attached to my house on one side (side shown in the picture). I want to frame and insulate the walls, but I want lose as little space as possible (since the garage isn't very large to start with and the opposite wall has only 2 inches clearance between garage door rails and wall).
Can I frame the walls with 2x4 on the flat edge (Tapcons into the brick/cinderblock, maybe glue as well), and then install 2" thick foam board insulation?
I want some kind of framing, so I can hang things if needed, and possible finish the wall down the line.
I tried looking it up and couldn't find any questions where the person had them attached directly to a sturdy wall.
  • You're going to be drilling into the wall for anchors. If you own the tooling for this, then the 2×4s seem unnecessary. Instead you might pinch insulation between the exterior wall and plywood or OSB. Install the anchors intended for the 2×4 into the plywood or OSB. The plywood or OSB will hold most hangers. You can fasten drywall to the plywood or OSB to finish the wall.
    – popham
    Dec 5, 2023 at 16:17
  • Would I be able to get away with glueing the 2 inch foam to the wall directly and then 1/2 inch osb/plywood. I dont hate this idea, although, i'd be interested in pricing out the difference in cost.
    – HomeinPA
    Dec 5, 2023 at 16:40
  • You could also glue drywall directly to the insulation to save a buck and a hair's breadth of thickness. Just keep the bottom edge up off the floor an inch or so. I have no idea what adhesive to recommend, though.
    – popham
    Dec 5, 2023 at 16:48
  • As per thisoldhouse.com/insulation/21195484/… yes, you can do the job with no framing, just glue/foam/glue/drywall. But that will impact the way to attach (or whether you even can attach) anything to the walls. A plywood/OSB face or that under 1/4" drywall will solve that one.
    Dec 5, 2023 at 16:59
    Are you planning to HVAC the garage?
    – Huesmann
    Dec 6, 2023 at 15:43
Yes, you can use 2x4s on the side as framing. (Or other sizes can work as well, see isherwood's answer.) But a few caveats:
  • A 2x4 is actually 1.5x3.5. So you would only get 1.5" for insulation.
  • Foam is relatively flammable. Whether or not it is dangerous when hidden inside walls, I would not recommend it in any significant quantity exposed, especially in a garage. The usual solution is to cover it with drywall. That will cost you an extra half inch, but will give you a finished surface, which will be better in a lot of ways. Since the drywall is not serving as a firewall (the brick is already doing that), you don't have to do a full tape/mud/finish/paint/etc. job. Bare drywall screwed into the 2x4s to cover all the insulation is really all you need. Proper finishing can be a future project.
  • Insulation is far more important on the outside walls. The wall that is a wall of your house really doesn't need it, though if you are going to bother with 2x4s (to hang stuff) and then drywall (to give it a smooth finished wall) then insulating at the same time doesn't add much to the cost.
    Good to know for the exposed foam board, It probably wont be too much effort to slap some drywall on it. especially if I can get away with not taping/mudding it. I am starting with this wall because I have to do this project in parts, and its more prudent to get the wall thats sucking warmth from the attached room insulated first.
    – HomeinPA
    Dec 5, 2023 at 16:36
    But, @HomeinPA, if you start with the exterior walls, then the garage will be warmer and it won't suck as much heat from the house. Added bonus: It's nicer to work in there, summer and winter.
    Dec 5, 2023 at 16:57
  • Yes you are right. and that is the overall goal. But If you look in the picture. The two non-brick sections where the windows used to be. are both the backs of built-in shelves and are like 1/8 inch plywood. Im guessing they are the biggest contributors to the heat exchange.
    – HomeinPA
    Dec 5, 2023 at 19:08
Furring strips are a common strategy and you'll find many related questions on this site.
Why would you waste all that wood, though? a 2x2 (1.5 inches on a side) is more than adequate, and if you want 2" you could rip a 2x6 into two boards and install them on edge.
Note that a wall's insulation value is taken as the average of the R-value across its area. Wood is a less effective insulator, and joints reduce R as well. Consider 19.2" or 24" centers (or the metric equivalent) to save wood cost and improve insulation.
    "if you want 2" you could rip a 2x4 into two boards and install them on edge" - a ripped 2x4 would be slightly under 1.75" (half of 3.5" and accounting for kerf). Considering the hassle of ripping 2x4s, if I wanted more than 1.5" for insulation I'd go with 2x3 on edge (giving 2.5").
    – Eli Iser
    Dec 5, 2023 at 18:23
  • Gah. Brain cramp. Thanks. Are you proposing 1" and 1-1/2" sheets? That's an odd size.
    Dec 5, 2023 at 19:00
