During the electrical upgrade, several PEHD tubes were laid through a hole in the wall (60cm thick). I am not sure how to fill the hole - want to keep the water and the dirt outside. Insulation is not a requirement, since it is in the basement (c.a. 70-80cm under ground level). I currently do not think that the wall outside will get insulated. It is currently in a dry area, i hope it stays dry, but want to keep it watertight as much as possible.
I was recommended to use well foam to fill the hole. I am rather inclined to use the foam from the inside, and from the ouside use something fluidic, that sets and hardens (e.g. some kind of asphalt/bitumen?). I also want to have it rodent-proof/insect-proof. How to fill the hole?
  • What's with the looped tube on the exterior?
    – Huesmann
    Dec 4, 2023 at 13:36
  • will be an outlet on the spot (right above the hole) if necessary
    – G. B.
    Dec 4, 2023 at 15:13
As a masonry wall, the obvious would be mortar of some sort, injected and packed around and between the tubes. If you want to add a waterproofing layer, do that after the mortar cures.
Given the tight spacing, an epoxy for masonry applications would be the other thing that comes to mind
    yeah, one of those caulking gun epoxies could be just the thing here.
    – Jasen
    Dec 5, 2023 at 3:21
  • how would you inject the mortar, so that it stays between the tubes?
    – G. B.
    Dec 5, 2023 at 7:41
    As opposed to flowing into the house? You just make your mix not too runny.
    – Huesmann
    Dec 5, 2023 at 13:23
Well, obviously the outside part should be filled with soil, compacted, and capped with concrete/turf. I think I'd throw some flowable concrete/grout at the bottom of the hole first to seal up the wall area where the tubes penetrate.
