I glued 2 of my fingers together with Rapid Fuse superglue.
I have tried rubbing alcohol, butter, and warm soapy water.
Per DAP's website for RapidFuse® All-Purpose Adhesive in the FAQ section
How do I remove dried adhesive? Cured adhesive may be cut away with caution using a sharp blade or removed with acetone (if appropriate/compatible with your application surfaces).
I personally like to wear latex or nitrile gloves when working with super glue; I don't like the chemicals on my skin and I use activator also, so it helps on that front as well. If I do get CA glue on an ungloved finger, I use a piece of sandpaper (like 220 grit) to remove it by moving my finger over the sandpaper; it is gentle and pretty effective.
The solvent for cyanoacrylate "superglue" is acetone, often found in nail polish remover.
Acetone/nail polish remover is the answer.
In addition to dissolving in acetone, cyancrylate also tends to have lower shear strength than tensile, and to be quite brittle. So try bending to fracture it, then slide/roll instead of pulling.
Most super glues are a type of ethyl cyanoacrylate (or CA glue). Fun fact: the glue cures when exposed to moisture. Guess what's in your fingers?
When CA glue dries, it forms an acrylic bond. None of your solutions will affect cured acrylic.
There's several answers mentioning acetone, but I wanted to add a word of caution. Be aware that acetone can start eating your skin after a while. Use with caution.
The best trick I know of is to use warm water on your bonded skin and carefully pick away at the hardened CA glue. Acetone can help in the extreme cases, but I do find your outer layer of skin can come off without any ill effect. Use acetone sparingly in trying to loosen tougher sticky situations only.
The one time this happened to me, I used a needle file with a D profile to gently work around the edges.
Do not use a sharp knife, the glue is harder than your skin and you risk cutting yourself.
Filing also removed a lot of the cured glue, though it left a dusting of old skin and glue on the bench. Best thing, it was relatively painless albeit embarrassing given it was in high school.
One option is to simply wait for them to come unstuck. This should happen in a few days to a week.
