I ripped out my old hardwood and left the old 3/4" diagonal subfloor down. The floor is mostly level. As for flatness, 3 spots need to be taken care of - each spot is about 3/16 to 1/4" deep. Where I can I am going to shim/shore up under the subfloor and screw down the floor with 1 3/4" subfloor screws. After that I am going to use ram board, tar paper, drywall shims to get it flat. After this is where I am getting confused.
- Do I put a underlayment like rosin paper first, shim, then put down the OSB or skip that?
- Do I lay down the OSB like I would normally with the ends landing on the joists then secure it to joist like normal?
- What about screwing the OSB to the planks as well?
- Since they are are 7" wide put a screw every 7 in-between the joist to hit a plank or not needed.
I am using laminate so there will be a underlayment on that.
Also I am using 3/4 to match the height of old flooring and it was cheaper by a lot.
