Objective: to install a new can light fixture, to be controlled by an existing wall switch. Original configuration: the wall switch supplies power to a ceiling fan with light kit.
What I did: I spliced the wires for the can fixture into one line of the existing circuit (14/2) between the switch and the fan. The result is that the wall switch continues to supply and control power to the old fan/light, BUT the light switch on the fan is also controlling the new can. Furthermore, the 3-way switch on the fan is dimming the new can with the differing degrees of fan speed.
Help needed: what should I do to correct the problem, so that the wall switch controls the new can and also supplies power to the fan, while the fan/light works correctly and independently as they did before?
I have not attempted to correct the situation by splicing into the other line in the existing circuit instead of the one I spliced into. It's all in the attic and I wanted to get input before dealing with all the fiberglass insulation and lack of lighting up there. Many thanks!
    Pics of the wiring would help. Your location in the world will let us know what type of wiring you're are dealing with.
    – RMDman
    Nov 26, 2023 at 22:41
