Background
Just bought a house with a passive air exchanger: no internal fans, just motorized dampers moving air with the furnace fan. We have a thermopump, electric furnace and whole house bypass humidifier.
Question
My air exchanger has this wye right after the "Fresh air to house" with a damper that dumps right next to the furnace. It looks like a cleanout? It is simply a register for this room?
Should I leave this open or closed? When and why?
air exchanger wye
(This question is split out from but loosely related to Air exchanger stale exhaust too restrictive? Some other issue?)
    An electric furnace will not need combustion air, so having it open/close will be more of your choice. Can try each way and see if it makes a difference.
    Nov 25, 2023 at 14:42
  • @crip659 Ah! I hadn't considered that it would be fresh air for a combustion furnace, as this system was installed after the oil furnace was removed. Thanks.
    – msanford
    Nov 26, 2023 at 0:01
    I am just guessing, but it does look like a damper is installed, so closing/opening/adjusting is easy. It should be in the close position right now, according to the damper handle position.
    Nov 26, 2023 at 0:29
  • Indeed there is a damper, which I kept closed. I think it's a very logical guess.
    – msanford
    Nov 26, 2023 at 2:56
