I have a 5 yr old Whirlpool range WFE745H0FS0. The temp keeps going up past the set temp by a lot with no error code given. Set to 350 goes to 500...more than a calibration fix...Control Board?
  • Does the oven have a digital readout that's showing you the 500° temp, or is that from a separate oven thermometer?
    Commented Nov 22, 2023 at 14:37
  • It could be the control board, it could be a temperature sensor. Have you checked to see if the temp sensor is reading valid values?
    – KMJ
    Commented Nov 22, 2023 at 23:10
