I just bought a home with a hot tub/pool in the backyard, and the hot tub is slightly elevated over the pool, and designed so that water will flow over the side of the tub and into the pool below (kind of like an infinity pool). I’ve noticed fairly large cracks in the top of the concrete wall of the hot tub and some of the water is flowing down into those cracks, rather than over the top and into the pool. My concern is that the water is causing erosion inside the wall, and if left unchecked, it will eventually collapse. The previous owners said it’s been in this state for a couple years (offer was as-is so I’m on my own for the cost, unfortunately).
I’ve had three contractors out to examine it and all three have said that it can’t be simply repaired, and will need to be torn down and rebuilt. Quotes range from $30-50k so I’m not keen to do the work in the short term. One of the contractors said it can probably be reinforced (via injecting epoxy or some other adhesive into the crack) and may last for years with this fix, but wouldn’t be able to guarantee anything.
Since the absolute worst case here is the wall collapsing (at which point I’d need to hire someone to rebuild it anyway), I’m inclined to go with the “reinforce” route in the short term. My plan is as follows:
Inject Loctite PL Premium as deep as possible into the cracks to strengthen the wall
Fill the gaps on top where cement has chipped away with 3M Bondo Putty to create a smooth surface
Coat the top with Gorilla Waterproof Rubberized Sealant Paste to prevent additional water from leaking in
Overall, does this seem like a solid plan?
One of my main concerns is that the Loctite will expand as it dries/cures (expanding inside the crack and actually making the problem worse), but I haven’t been able to nail down clear info on whether it will expand or not (seems like this may be the case for polyurethane adhesives?). Loctite PL Max seems to be a good alternative if this is the case. Anything else I’m missing or should do instead?
Here are photos of what I'm working with:
Side profile of tub, wall, and pool:
Closeup of additional tiles that are separating but haven't yet broken off:
UPDATE 11/7:
I've included two videos of the pumps running which causes the water to flow over the wall, which in turn gives a better view of exactly where the leaks are taking place. The large crack (where the tiles are missing completely) causes the water to flow all the way to the bottom of the wall and out where a couple more tiles are missing, while the smaller crack where tiles are being pushed upwards causes the water to flow out mid-wall, between bricks in the facade.
I also contacted Loctite regarding the possibility of expansion upon curing and they responded that their Concrete Non-Sag product would actually be a better fit for my purposes. They didn't answer the expansion question, however, so I've followed up and will update this post when they do.
Front view of water running (one leak at bottom and one leak mid-wall). This view also shows that this isn't the first time water has leaked through, and the previous owners clearly did some (rather messy) repairs: https://imgur.com/a/zCl4LhY
Top view of water running with closeups of the wide-open crack in the middle and smaller crack on the far side: https://imgur.com/a/XrXvBa2
UPDATE 11/8:
Three additional photos (forgive the dirty pool - it was windy today!):
Close-up of missing tiles at bottom of facade:
