We have recently moved in to a 1930s house and are renovating the downstairs. We have just installed a large boiler and hot water tank. The bath has 2 separate taps (faucets) and both have about 18L/min of flow.
The shower in the same room only has 11L/min (measured by unscrewing the main shower head) regardless of temperature (and the same for the identical shower in the en-suite next door). Both have 2 shower heads (one fixed and one hand held) and when I switch on both at the same time I don't see a noticeable drop in pressure and perhaps get 14L a minute which to me implies the shower's mixer is to blame.
The shower is a Crosswater DL2000RC. My theory was that someone had reduced the pressure to accommodate two showers on the old boiler but I no longer have such a constraint.
I have tried loosening the red screws a bit which didn't seem to make a difference. Should it? What do they do? how far can I unscrew them? do they stop or do they completely come loose?
I note that the dials to enable each shower theoretically have pressure adjustment in normal operation via twisting them, however turning my handles has limited effect either way.
Any other ideas?
instructions
  • Open up the things you marked with a red dot in your image and check if the filter is dirty. Be sure and lightly grease the seals with silicone grease when you put it back.
    – Ariel
    Dec 7, 2023 at 9:35
There is a flow limiter in the head of the shower units. I suggest removing the head and testing the flow. If it improves then you know it is the shower head rate limiter.
I don't know that opening the integral shutoff at the shower valve will actually improve flow (possibly if it was used to restrict flow).
    I have updated my question to clarify that the measurement was taken without the shower head. Any other ideas?
    – Joe
    Nov 7, 2023 at 7:35
