Can I put screws in the molding of our standing shower stall in order to install curved shower rod?
  • 4
    HI Corinne, a picture would help people answer it better. Nov 7, 2023 at 0:27
  • Recommended only if there's a stud behind the wall, otherwise the torque of the (wet) curtain on the rod will cause the fasteners to loosen.
    – Huesmann
    Nov 7, 2023 at 12:54
Yes, of course you can. The attachment method will depend on the molding material and its thickness, and perhaps on the type of wall that sits behind the molding. I recommend drilling pilot holes prior to attempting to screw into the molding, using stainless-steel screws (so they don't rust), and sealing them up with caulk so water does not run into the wall.
