I have a circuit with 3 Leviton smart dimmer switches that control 3 different LED ceiling lights, 1 on/off bathroom fan, and 1 on/off LED light. Whenever the 1 on/off LED light is turned on, 1 and only 1 of the dimmer-controlled LED ceiling lights flashes. It's a sputnik-style ceiling light with 12 dimmable LED bulbs in it. The other 2 ceiling lights never flash. The LED bulbs will probably not last as long because of this, but it's damn annoying because it's in our bedroom.
I did some Googling and came up with something called "neutral interaction." Could that be what's happening here? I can't get to these lights' wiring in any way except for at the base, so I can't run another neutral. They're on vaulted, angled ceilings with no attic above them. Is there any way to stop this? Could I put something (diode?, resistor?, filter choke?, ferrite ring?, Lamp Debuzzing Coils (LDCs)?, magic beans?) on the neutral line to this light to stop this?
    do all 12 bulbs flash, or just one? Do they flash continually or just when the on/off changes?
    – dandavis
    Commented Nov 6, 2023 at 19:50
  • All 12 bulbs flash very quickly just once.
    – pennstump
    Commented Nov 7, 2023 at 3:29
  • That's a lot of bulbs. I would try a different/better dimmer and/or lower wattage LED bulbs. I've had good multi-bulb luck with old-school dimmers and the right LED bulbs; the older dimmer probably has a beefier snubber network on the dimmer. You could also try adding a snubber network across the existing dimmer, there's commercial modules if you don't want to hand-roll one.
    – dandavis
    Commented Nov 8, 2023 at 19:44
  • Is a "snubber network" the same thing as a shunt capacitor / MLC?
    – pennstump
    Commented Nov 8, 2023 at 19:48
  • en.wikipedia.org/wiki/Snubber
    – dandavis
    Commented Nov 8, 2023 at 19:50
I’m not saying this is what is happening with yours, but I had 4 dimmable LED ceiling lights (the flood style lightbulbs) that started strobing every few seconds a few months after I put in a dimmer switch. I swapped out the dimmer switch thinking it was bad, but the problem continued. So I swapped the four builder-installed lightbulbs for four new LED dimmable bulbs and the problem stopped.
  • Thanks, but I've tried 3 different dimmable LED bulb brands. All seem to flash the same.
    – pennstump
    Commented Nov 7, 2023 at 19:03
