I currently have a standpipe for a dryer (no p-trap and unvented) which connects (via some elbows) to a horizontal sewer line in the basement. I would like to (a) install a p-trap in the basement underneath and (b) drain condensate of my HPWH.
Please see the current setup along with a picture on the left. On the right, how I would want to install a part like this. As far as I know this would not be perfectly compliant because the washer should have 2". Hence I would consider building exactly the same myself out of PVC or ABS fittings.
Note: As far as I know AAVs are allowed where I live (San Mateo, California), but even if not, it would only improve the situation. I do not have the resources to create another vent or to connect to the vent from the BR sink. It is buried inside the wall and I do not want to open the wall.
