I moved into my house last year, the bathroom has pot lights and had a walk in tub. We are now installing a shower and a pot light will be in the shower. Is there a way to tell if the pot light originally installed is wet rated? Located in Ontario
Find a make/model number on the thing and look it up. Or, possibly, while looking for the make and model number, find a label that indicates it's wet-rated directly.
I suspect CEC and NEC are sufficiently similar that it will need to be GFCI-protected if in (or even close to) the shower.
This site is temporarily in read-only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
