A disconnect is not a protective device for the wires or equipment. It can act in that way, but the primary purpose is so that you can definitively turn off the equipment within sight of the equipment for safety purposes during repairs and maintenance.
A disconnect also serves as a way to disconnect power during an unrelated emergency such as a fire so that there are no live wires in a dangerous area. That is the disconnect for an entire service as required in the latest NEC. Although generally for other reasons that is done using a meter main, it can also be done using a disconnect.
Just like the disconnect for your entire service can't be a 60A disconnect if your service is larger than 60A (which is nearly always the case), you can't use a 30A disconnect for equipment on a 40A circuit.
So the real question is: What size is the circuit for this equipment?
26A can be the maximum current draw or it can be the continuous current draw. If it is the maximum current draw then, in theory, you could use a 30A circuit breaker and 10 AWG wire. However, I suspect it is the continuous current draw, in which case you have to size the circuit to be at least 32.5A, which means at least a 35A breaker. 35A breakers are a thing. However, for a bunch of reasons including ampacity ratings on copper NM cable and aluminum wire and the ability to allow for future larger equipment, a 40A circuit is very common, and the equipment ratings allow that.
Which means most of these installations will be done with a 40A breaker and appropriate cable/wires (e.g., 8 AWG NM or UF cable). Which means the disconnect must be at least 40A. Disconnects are available in only a few sizes because the primary protection, with a very specific rating to match the wire and equipment, is provided by breakers in the panel and not by the disconnect.
Because these disconnects are so standard - only 2 sizes (30A or 60A), needed for every HVAC installation (and sometimes for other types of equipment), they are really very inexpensive. Looking at Home Depot, I see a range of ~ $ 15 to $ 30, depending on brand, 30A vs. 60A and some other factors. Not a lot of money compared to the HVAC equipment or even wire costs. The only ones that cost more are ones with a convenience GFCI receptacle included. That is actually a nice way to also take care of the requirement (relatively new) of having an available 120V receptacle within a certain distance (I believe 25') of HVAC equipment, which can be used for refrigerant recovery or other servicing needs.
This is actually the exact same issue as "main panel breaker size" when using a "main panel" as a subpanel for an outbuilding. The main breaker in the panel is only functioning as a disconnect. So you might have a 60A or similar feed, depending on how much power you need in the outbuilding and on how much power is available in the service after doing a Load Calculation on the main building, but the panel in the outbuilding can easily be a 200A panel with a 200A main breaker. And that's just fine.
