I am trying to drill for some curtains.
I was assuming that my walls were plaster, because my stud finder was useless and the magnet was not sticking to anything.
I am using titanium (coated?) drill bits 3/32 bit.
This is about 6 inches to the side and above the edge of a window. the window frame is steel (my magnet sticks) and extends about 2 inches or so from the edge of the window.
There is an outlet directly under the window, but there is the light switch for the living room lights about 1 foot from the left side of the edge of the window.
I got about a quarter inch in before I hit something hard that my drill was not cutting through.
I gave it a half second of drilling on low speed to see if I would see any metal filings, but I did not see any.
However when I scratch a smaller bit against the end of the hole, it does feel like metal.
Additionally the magnet is not sticking to the location that I was drilling. So I can't imagine that would be a plate on a stud, since I have only heard of using steel for such a thing.
Also the hard surface seems pretty flat from what I can tell, I cant imagine it would be conduit (with a circular cross section).
Finally, the same thing happened on the other side of the window at the same height, again 6 inches to the right of the window.
This is the outer wall of my apartment, facing into the apartment complex.
Any idea what I am hitting? It cant be brick or steel. I will ask my landlord but they might just ignore me because landlord.
    edit: the reason was because my drill was going the wrong way. There is no metal object. Commented Nov 1, 2023 at 2:30
  • 8
    i am leaving this up for people to make fun of me Commented Nov 1, 2023 at 2:30
    thanks for being a good sport,.
    – Jasen
    Commented Nov 1, 2023 at 3:19
    You are not alone, although most would not say anything. On a commercial construction project, one of my crew spent most of the afternoon fighting to drill 1/4" holes in metal studs. After complaining, one of the other guys teased, asking if the drill was going the right direction, to which the response was: "What do you mean? Drilling is drilling!"
    – red_menace
    Commented Nov 1, 2023 at 5:43
    If you intend to leave this up for future searchers, could you please put the solution in the answer space & mark it as accepted. The 'reddit style' of putting solved in the title & the answer at the end of the question does not work for Stack Exchange.
    – Tetsujin
    Commented Nov 1, 2023 at 8:05
The reason this happened was because my drill was turning the wrong way. There is no metal object.
    Thankfully you didn't keep going and work hardened it too much, or even set your wall on fire.
    – Nelson
    Commented Nov 2, 2023 at 5:46
