When I moved into this house earlier this year, the sump pump had a black hose connected to the pipe like the one here except the old one was super beat up (probably got ran over by a lawnmower).
I bought a new hose and it’s been working fine but I’m wondering if I should be using whatever that white pipe in the ground is? I tried to find another end to that pipe but couldn’t find it.
That is presumably a clogged or poorly installed underground drain for the gutter downspout and/or sump.
Presumably it's now disused due to clogging or dumping water back in the basement to be pumped in circles.
Without cleaning out and/or correcting, it's probably still clogged or poorly installed. If cleaned out or corrected (or replaced wholesale with a correct underground drain) it might be preferable to the present arrangement.
If you get real winter, you might need a larger diameter sump pipe so it does not freeze up, rather than the small black corrugated.
  • Thanks! We do get real winters here, and it’s already getting cold. Is it sufficient enough to remove the black hose for the winter? Or do I need to get someone to look into the potentially clogged drain? Commented Oct 30, 2023 at 16:47
  • You will want the water taken away from the building. I was suggesting just changing the small black pipe to something like a 3-4" pipe or section of downspout, sloped to run away from the house so it will drain between pumpouts without collecting a lot of water to freeze into an ice plug. That would be quick and inexpensive, compared to needing a rush job on the underground pipe.
    Commented Oct 30, 2023 at 16:57
  • Gotcha. I found a YouTube video describing exactly what you’re saying. I’ll go hit up the store later today. Thanks again so much! Commented Oct 30, 2023 at 17:06
