I am trying to match a new deck color to an existing deck that was stained with Olympic Maximum stain and sealant in the “natural tone cedar” color. I purchased the wood rx product in the cedar color hoping that they would match pretty closely. They do not. Can I mix the Olympic Maximum with the wood rx to try to match the colors closer? I believe both are water-based. I have probably just enough of both left to finish the new deck.
The deck to the right is 2 years old. Stained with the Olympic Maximum 2 years ago. I recently pressure washed it and then applied one coat of the Wood rx.
The left deck is new. It has one coat of wood rx on it.
    There are no photos in your post for us to see what you're talking about.
    – matt.
    Oct 28, 2023 at 19:23
  • Thanks for letting me know. I guess the file size was too large so it didn’t upload the first time.
    – Danielle
    Oct 28, 2023 at 21:12
You can try - likely there will be noticeable difference of new to old until 2 years difference is an insignificant part of their time in service.
It's hard to predict how mixing the two products will go, even if both are waterbased. Try mixing only a small amount as a test.
