I have a cabinet with a locking mechanism that's missing the pin shown in the following image from an identical cabinet. (Looks like a brass pin with a black crest-shaped clip holding it in place.) Can someone let me know what it's called so I know what to ask for.
    A grooved clevis pin and side-mount external retaining ring (I assume the reverse side of the pin has a rivet head shape). Get a bolt, nut, washer, and some threadlocker instead of trying to match that. Or beg the manufacturer for a replacement.
    – popham
    Oct 25, 2023 at 5:11
    Those black retaining clips are also known as "jesus clips" as when they ping off "jesus, where did that go"... :)
    – Solar Mike
    Oct 25, 2023 at 5:52
  • 4
    that's an E clip ... duckduckgo.com/?q=e+clip&iax=images&ia=images .... or a C clip ... duckduckgo.com/…
    – jsotola
    Oct 25, 2023 at 6:33
    @SolarMike One reason I have a kit with different sizes.
    Oct 25, 2023 at 11:15
    Ahem... @popham... Answers go below...
    Oct 25, 2023 at 12:45
If the entire pin has gone missing, then simply replace it with a bolt of similar diameter, and put a washer and lock-nut on the end.
Use a lock-nut so that you don't have to tighten it all the way up (which would prevent the other piece from moving).
An alternative to a lock-nut would be a pair of regular nuts - one tightened against the other.
If it's just the clip on the end that's missing then you can find packs of various size 'E-Clips' at all the usual places.
