all! For some reason Great Stuff offers all of their cans in Pro style, but not the Big Gap Filler. I have 3"-ish gap between a base plate and a floor joist in the basement that has very little insulation behind it. The reason is I think that the gap between that joist and the foundation wall is basically half an inch. I am guessing it was nearly impossible for the builders to wedge regular fiberglass insulation in there, or they were simply lazy. I think this would work really well insulated with foam. In fact, Big Gap Filler, with its advertised 3" expansion might be the ticket. Alas, it is not made in Pro gun style, which seems quite useful for controlling angle and thickness. Could I simply run multiple layers of the regular stuff, even if it's advertised to only expand to 1"? Am I overthinking it, and I should just liberally ugga dugga the gap filler in there?
Cheers
