This is a question that’s been asked quite a few times but every sink seems a little different. I just moved into a house and within 2 days of moving in the kitchen sink stopped draining… I’ve plunged it aggressively, I’ve done the warm water, I’ve used baking soda, all nothing. The P trap is clear, the pipe all the way to the wall is clear.
I’ve had a lot of trouble getting the snake around the turn at the back of the cabinet (I know it much be a turn because the back of our house is behind the cabinet).
From timing how long the sink takes to back up, it seems like it’s clogging with a relatively small volume of water that shouldn’t be much beyond the pipe junction at the back of the cabinet. I’m just confused as to what I could’ve done to clog the sink literally within days of moving in.
There’s no garbage disposal so we’ve been actively not putting things down the sink.
What can I do? Keep trying to clear it? See if our roof vents are clear?
This house just has a lot of things that were done kind of shoddy on it, so I’m trying to see if there’s a bigger issue that could’ve caused a clog so quickly. It’s a 1953 house and I know from the inspection that whoever switched out the original galvanized pipes made some basic mistakes- such as with regards to proper grade (we had a sewer scope/inspection done on everything below the crawl space access, and they’re things that shouldn’t be a huge issue but were just dumb).
I’ve pictures but there’s a section of pipe at the back of the sink that’s closed off. I originally thought it was cleanout access based on what I’ve seen online, but it’s definitely been glued shut? So I think potentially a section of the old galvanized pipe that was replaced?
