We have gotten attic rain the last 4 years. This was due to the bathroom fan not being air tight, weak/old fan, and having -30c temperature freezing the humid air and then melting in spring. This would cause water to come through roof.
So I bought a new roof, new vents, and got a new humidity sensing bathroom fan, made it air tight. It is supposed to be 'silent' however it sounds like an airplane.
If I do not have the black actual fan fully inserted into the housing it is fine. If I put it in all the way to secure it, it sounds insanely loud. I have tried re-seating it multiple times, adding foam to dampen the sound but nothing works.
I can't shower when the kid tries to sleep because it is so loud.
What can I do to reduce the noise from this fan?
Some videos of it I posted to imgur. Foam isn't pretty. But it helps keep the area air tight.
