I attached a watt meter to my fridge and these are the readings after 4.5 days.
Usage 5.17 KwH
Hi 1500 W
104.5 W
.916 A
.99 Power Factor
116 V
Looks like the last four readings are a snapshot: V * A * PF = W
Since the readings took 4.5 days, I divided the KwH reading by 4.5 and came to 1.14 Kwh.
So would it be fair to say the fridge consumes on average 1.14 KwH every 24 hrs. with a surge of about 1500 W?
I'm also considering getting an inverter to power the fridge as a backup.
Given the above numbers, what's the minimum.
Thanks.
    The 1500 is probably start up power, and depending on the fridge might happen quite a few times a day for about a minute each time. I would want something more than 1500w.
    Commented Oct 2, 2023 at 22:50
  • Or it might be the defrost heater(s)
    Commented Oct 3, 2023 at 2:37
Yes, that is consistent with everything I know about fridges, including my own testing. Mind you, these are units that do not have ice water in the door.
My rule of thumb has always been you need 1 kWH per day to run a fridge.
