Is there a good code-compliant way to vent the following exterior water heater (see attached drawing).
I thought this concept would work, but I am stuck trying to figure out a good way to vent.
The best I have is:
out the shed-top, 45 to under rafter-tail, 45 up through rafter tail
90 inside enclosure to stucco wall, 90 up through rafter tail
Either of these ideas, i do not know if they are code compliant?
Any suggestions/help would be appreciated, thank you.
This is in the Central Valley California.
9/21/23
9/22/23
Revised site-plan drawing (to submit to city):
10/17/23
In the end, my initial drawings did not work out because of local building setbacks to the property line/fence (requiring a 5ft setback from the structure to the fence).
I had to redraw the plans. But it has now been approved, with the vent going straight-up and out.
