I am troubleshooting an electrical problem and am having trouble understanding the readings I am seeing on my digital multimeter. I am a DIYer with just the basics of electrical engineering knowledge, but would appreciate comments on what I am seeing and the physics behind it. Would this be expected based on Ohm's law?
Below is a schematic of my circuit which supports three electric baseboard radiators controlled by a single wall mounted thermostat. The heat had stopped working and when I removed the thermostat I found 2 tiny baby mice in the electrical box! After removing the mice I wanted to test to see if there might be any anomalies indicating chewed wire damage inside the wall and got the voltage readings shown on the diagram.
For those outside of the US and Canada, note that we get 220V by going across the two 110V wires from the line source, whereas our 110V is done by going from one of the two 110V sources to the neutral. So I understand the 120V reading on the first measurement.
I am not clear however as to why I got the other two readings. Note that all of these readings were taken with the thermostat switch open.
My question: Are the 20V and 70V readings I am seeing to be expected voltage drops due to the resistance of the radiators? Or could it be an indication of some line damage hidden in the walls?
Ohms law disagrees. Since the thermostat is open, current is zero, so voltage drop due to Ohms law (V= I * R) is (V= 0 * R) is (0) that's (zero.)
So, the "70V" reading should be 240 (you're doing the common but wrong for 5 decades or more bit of calling 120/240 110/220) and the "20V" reading should be 120V. The "120V" reading is as it should be.
Both "70" and "20" are probably "phantom" voltages (high impedeance meter showing voltage capacitively or inductively coupled onto a wire) and probably indicate a disconnected wire from the other side of the 240V supply to all the radiators (since any one radiator being connected should cause the correct voltage to appear at these points, if the diagram is accurate.)
One thing to look out for is that many North American resistive heat thermostats are actually wired to open both sides of the line, which would be one way for the other side of the line to be disconnected from the radiators. That's not what you've drawn, but if you oversimplified the drawing, it might apply.
  • Thank you for the clear answer. It was what I was worried about -- a disconnect somewhere. Thanks for the warning about the thermostat wiring -- but in my case the (expletive deleted) contractor who installed this used a double pole thermostat but only wired up a single pole. The other line is hardwired somewhere under the floors. Thanks again for your answer.
    – lp1756
    Sep 20 at 18:51
Because you're running the box or panel with missing knockouts, a code violation. KO covers are 30 cents.
On your 70V measurement, since the switch is open, and your voltmeter is taking micro-amps, the resistors/radiators are functionally deleted and you can now see that your voltmeter probes are now directly across the "220V" source.
Thomas Edison started with system voltage of 100V and did voltage bumps to 105V and 110V to increase system capacity while not instantly blowing people's light bulbs. It had reached 110V when Edison lost the War of the Currents, so Tesla/Westinghouse adopted 110/220V split-phase as a national standard and filled every advertising channel with the call to hook up to 110V. Sometime around WWII they started another series of bumps and arrived at 120V around Vietnam, but in slang speech, 110V and 220V stuck like Kleenex in a Xerox.
That's how you can have a "220V" source but 120V measured value to ground.
If you are in a 120/240V split-phase country, or a 120/208V or 127/220V location, you should be seeing 110-127V between either phase and ground. Apply the above logic that the resistors functionally disappear when not under load, and you can see your phase-ground voltage should be 120V-ish, not 20V.
I suspect a lost phase. Either in the circuit or at the electric service.
    Thanks for your response. Regarding the knockouts -- Interestingly and amazingly there are no missing knockouts. The box is plastic with one romex cable coming in through the one hole with that tight plastic thingy which acts as a cable stabilizer and hole cover. There was hardly a quarter inch of space for these baby mice to squeeze through. How they did it is beyond me, but there they were! The mice were about an inch and a quarter long, sans tails.
    – lp1756
    Sep 21 at 0:24
    @lp1756 re mice - they can disjoint their hips and a wild adult can fit through a hole the size of a ballpoint pen. A 6mm hole would be like an airplane hanger door to a smaller mouse.
    – Criggie
    Sep 21 at 2:52
