Ok here is a doozy we have been dealing with for over a year.
House was a new build 2012 and we had never had any plumbing issues until we had our roof replaced a bit over a year back and around the same time began to experience occasional sewer gas smell from the shower floor drain and also across the house from the washing machine, but only while actively in use draining water. Over time it has progressively become more consistent (it is now daily) and stronger odor. I used a flammable/sewer gas detector and it registered up to 50ppm after the shower ran for approximately 5 minutes, then when shut off returned to zero. In the laundry room the gas odor stays in the washer tub until the room gets sufficiently aired out.
Based on the coincidental roof replacement, I assumed the "upgraded" wrapover roof vent boots somehow were constricting the vents and so we had them all replaced with standard 3 in 1s with new extended PVC. This did nothing to address the issue. Plumbers also ran cameras down the vents to check for obstructions and everything is clear and clean. I used my endoscope and verified both the shower and washing machine traps are holding water and not dry.
We then ran cameras from the rearmost cleanout adjacent to the master bath all the way to the sewer tie and and found no leaks, clogs, or issues. Similarly we checked the front yard main cleanouts both into the house and away towards the sewer and found it to be in nearly new condition with no leaks or clogs. As a test, I uncapped the main cleanouts in the front yard and ran the shower, and still got sewer gas smell coming from the drain (this is what is most confusing). What is also unusual is that if we leave the house for a vacation and return after no plumbing has been used for approximately a week, we do not get any sewer gas for 2 to 3 days before it completely returns.
We next called and had the city perform a sewer pull and degrease/washout which also had no effect.
As of today we can hardly stand taking showers, especially at night. The entire master bath and bedroom is overcome with sewer gas on a daily basis. The washer tub gas is less consistent - some days we can run the washer with no issues and other days it too becomes overwhelming.
Not sure what to do now - none of our other drains have any issues including half bath, 2nd bath with kids shower, kitchen sink, etc. I cant make much sense of what could cause sewer gas to pressure past the shower trap while it is actively draining instead of simply exiting though the roof vent like it presumably had been doing for over the past decade. I even tried installing a backflow preventer in the shower drain but as soon as there is flow through it and into the trap, the gas is seemingly bubbling past and into the shower.
Currently at wits end, my plumber essentially gave up on us. No idea what to check next. Help!
