I want to use my garage as a workshop, but it is currently not well lit. How can I estimate how many lumens of lighting fixtures I should buy?
I'm confused about the calculation, but also lighting seems to be a bit subjective. I am rarely annoyed by rooms that are too bright but I often get bothered that they're dim. I don't want to do a bunch of work installing lighting, only to discover that it's too dim for my liking and I need to start over.
What factors are relevant for this?
- Do I go by lumens or foot-candles?
- Does size of the garage matter?
- Does shape of the garage (ie. long vs. square) matter?
- Does the height of the ceiling matter?
- Does the color of walls affect it?
- Does it matter that some lights are omnidirectional (bulbs) while others (strip lights) direct it all downwards?
- What about the contribution of windows?
From searching on the internet, I basically find that a workshop should be "800-1000 lux" and that you need lum = lux * sqft
. However, how can this formula be correct if it doesn't take into account most of the above? What is the correct formula?
