When you see the exterior of the window it looks quite spoiled due to hot son and humidity and moisture during rainy season.
But interior of the window looks quite new.
This window wood was properly treated with primer , sheenlac sheen two times to make sure the quality doesn't fade away.
This is how the exterior of window looks like
This is how to interior of the same window looks like
Please find this window also
Basically as the windows and doors that are exposed to the sun has lost its sheen.
I'm just wondering, does it require immediate varnish and wood finishes.
or it's just matter of looks we can and redo this , whenever we can afford to do like after 3 years.
Someone please share their wisdom and insights.
FYI:
I will update this pics of the wood doors that are exposed to sun rays.
All the windows and doors have concrete shade , just mentioning.
9
    For outdoor wood, I've always used a soar varnish. These have additional UV blocking agents, and if I remember correctly they are also more elastic, so they handle sunlight and weather better than mist varnishes. Even so they need to be sanded down and recoated periodically.
    – keshlam
    Sep 18, 2023 at 6:51
    It might also behoove you to clean up the joint between wood and glass, and run a narrow bead of clear silicone caulk, to prevent water from getting in.
    – Huesmann
    Sep 18, 2023 at 13:10
  • Thanks for reminding me to caulk it. I'll have to find a brown color caulk probably so that it blends with the frame
    – King
    Sep 18, 2023 at 14:24
  • Correcting typo above: Spar varnish, not "soar". Sorry.
    – keshlam
    Oct 9, 2023 at 2:48
  • I think that the urgency of making repairs depends on how much damage you're willing to tolerate looking at. If you think it looks bad enough to repair/refinish now, then get on it. If you're willing to put up with the look, and possibly spend more money/time fixing it later, then put off the maintenance.
    Oct 9, 2023 at 17:02
