Building a set of floor to ceiling bookshelves along a wall in the living room. Using 2 7/8 wide, 3/8 thick hard maple wainscot for the backing of the shelves. Pricier but looks so much better than plywood or particle board backing. I plan to use 1 1/4” wood or construction screws to attach a board to the wall studs every 16”. Question… should I affix the boards to the drywall so it doesn’t span 16” before being screwed to the wall? If so, what screws (drywall?) would you use? I want to be able to remove the entire unit if we move, hence the desire to use screws and not brads, epoxies, etc. TIA
Attaching to the studs should be sufficient.
I would have a screw at the top and middle of each stud. I would also recommend using some longer screws. With ⅝" drywall you're only getting ¼" of penetration. With ½" drywall you'll get ⅜". I'd go with a 1⅝" screw, it'll secure things much better.
As far as screw type, I'd use a stainless fine thread. Fine thread screws have a higher tensile strength making them the stronger option.
  • The other idea I had was to run 1x2 or 1x3 furring boards horizontally and then screwing every other panel board into the furring strip. I plan on having rear support for the shelves screw into the wainscot, so using longer screws and going into the furring strip too might be a good idea for shelf support. Overkill??
    – user173624
    Commented Sep 13, 2023 at 2:23
  • I have several 7'x3' bookshelves and have them fastened directly to the studs and they're solid. My youngest boy is a wild one, climbs on everything and I don't worry about the shelves coming loose. With the thickness of your backing I would be perfectly fine securing them directly to the wall
    – matt.
    Commented Sep 13, 2023 at 2:57
  • @matt but it sounds like the OP plans to fasten the shelves to the wainscot, not to the studs.
    – Huesmann
    Commented Sep 13, 2023 at 13:52
  • @Huesmann My understanding is that he is building floor to ceiling bookshelves using a 3/8 maple for the backer board of the entire unit. Unless I misunderstood his question my answer remains the same. Screw through the units backer board (3/8 maple) directly to the studs. This will sufficiently secure the unit.
    – matt.
    Commented Sep 13, 2023 at 14:14
  • Yeah...not clear if he's using the wainscot for backing the shelves, like attached to the shelves, or basically using it as wall paneling and building shelves with an open back.
    – Huesmann
    Commented Sep 13, 2023 at 14:29
