A few months ago I had laminate floor installed in a bedroom and it is now buckling. After removing the quarter-round and inspecting it, I see that the installer did not leave a gap between the edge of the floor and the walls; There is no room for the floor to expand.
Is there a tool that can allow me to cut the floor along the perimeter of the bedroom so as to leave a 3/8" gap.
My circular saw isn't capable, and it would take a long time with my oscillating tool.
  • Get the installer back there to do the cutting.
    – JACK
    Sep 5, 2023 at 19:51
The saw you are looking for is called a toe-kick saw. Harbor Freight sells one. These days most people use an oscillating multi-tool for this job. It will take longer to do the job with the multi-tool, but then you have a really versatile tool in your toolbox.
The dremel Ultra-Saw Compact Circular Saw might be able to get close to the wall and do what your circ can't.
dremel circ saw
    I have this tool and like it, but to do flush cuts, it requires a special blade that's quite expensive.
    – Cheery
    Sep 5, 2023 at 11:20
  • yeah looks like you need a raised center blade - Dremel SM600 MultiPurpose Flush Cut Carbide Wheel. Sep 5, 2023 at 15:30
