I have a pull-chain lamp that is in need of repair (the pull-chain doesn't always turn the lamp on)
Would I able to swap this out with a turn-knob?
I have seen some youtube videos, but they all mostly describe replacing the socket/switch with the same type.
  • Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking.
    – Community Bot
    Sep 5, 2023 at 8:23
A photo would help.
If you mean the pull-chain switch is part of the socket, then yes, you can easily replace that with a socket that has a twist switch.
If the switch is mounted separately, then it's probably still easy to do but would require more disassembly/reassembly.
