When I turn my plumbing tap on , it gives some whistle sound and I always get the sound , every single time.
Please find AV clip here.
None of the water taps give this whistle sound , how can I get rid of this noise.
Should I be worried ? Should I do something about it ?
Update:
The water comes from over head water tank in terrace
Update 2:
After cleaning the aerator , the sound stopped in the tap.
Please find below two AV clips: These below taps there's always a turbulent water flow .. I wonder some air bubble cause it . why ? this always happens , there are no aerators attached as well.
Please find the below AV clip: All the taps except above two has streamlined water flow.Please see the video of streamlined water flow.
