I have a basement wall that was framed but never finished by the previous owner. I would like to complete it but want to be sure I’m doing things correctly.
From what I can piece together I should be using foam board (but getting some mixed messages on if EPS or XPS is better) directly on the poured foundation. Then more foam board used to insulate the rim joists (with proper sealing around all of this).
I’m zone 6. If I’m understanding things correctly, no vapor barrier is needed if I use 2” foam.
What I’m stressing over is there’s a dryer vent behind the studs. What is the best way to handle that?
The vent is 4” so even with the foam there will be a space between the studs and the foam board.
Do I put the foam up to the dryer vent and do something different in that area? Just fill all the open space with rockwool?
I think without the vent I have a pretty good handle on what needs to be done, but the vent is kinda freaking me out and I want to be sure I’m not doing a critical step wrong.
I added a couple pictures, but any help would be really appreciated. Thanks so much for anyone that has some input!
