I am aiming to babyproof this unit to the wall. It is three separate, vertical pieces. For the rightmost and leftmost piece, for where they are, there is one stud behind each of them.
I can secure them to the wall by either using the default drywall anchors they came with or I also have these and can secure them to either the drywall (two on each corner) or the stud in the center.
Which is more secure / recommended?
Is there a better, more safe way to go about this?
Thank you
