Is it possible to combine 5 watt electric LED string lights with E26LED lamp socket to be powered with a single switch? The hope is to use a single switch to light up the planets (string lights) and the sun (E26 bulb). Have very little experience. Alternate ideas welcomed & thank you in advance.
Please see attached
[![enter image description here][2]][2]
PLUTO ADDED. :) [2]: https://i.stack.imgur.com/pPGIr.png
  • They forgot Pluto. I did not spend years in school learning Pluto is a planet to have it taken away. If the switch is on the light, you just plug it in. If no switch on the light you will need a switched outlet.
    Aug 20, 2023 at 19:52
  • Pluto added. Thank you; the 7-yo would have been disappointed!
    – Dodger
    Aug 20, 2023 at 20:16
  • FYI, if it is more convenient, you can find 12v e26 bulbs. Aug 21, 2023 at 2:46
If both the string lights and the bulb are made to run off 110V (US) and both are made to plug into a standard outlet then YES !
You didn't indicate if you had a switched outlet or something set up for this.
If you don't and need direction to make a switched outlet, let us know. or you can purchase a UL listed switched power strip
    The US is standard 120v these days. Some people are picky about it, some just eh close enough.
    Aug 20, 2023 at 20:14
  • Appreciate the guidance; this is exactly what I was looking for. Thank you for taking the time.
    – Dodger
    Aug 20, 2023 at 20:19
