I’m replacing a sink base cabinet that’s seen damage through the 3/4 ply underlayment, but the 3/4 OSB subfloor underneath might still be in good shape due to a vapor barrier sandwiched in between. We’re planning on removing the old cabinet and making way for an ADA compliant one so my dad’s wheelchair can access the sink.
The work I’m planning is replacing the damaged 3/4 plywood, installing 1/4" Hardie backer and some tile.
Can I replace the 3/4 plywood underlayment with 1/2 ply since there is already a 3/4 OSB subfloor beneath?
