I got this old place recently and the tub faucet has been leaking like crazy. I tried google videos and can't find anything on how to remove this type of faucet/stem. I don't see any hex nut to remove it and the black part is just a washer.
Any ideas on how to approach this?
Here is the picture.
  • Can you post some more detailed photos that show clearly the areas between the outside threading and the tile? I think you may need to put a rag over the threads to protect them, then use slip joint pliers to carefully unscrew the threaded part counter clockwise.
    – Armand
    Aug 16, 2023 at 16:11
Try turning the stem counter clockwise.
It looks as if that is ready to come out, if it would be turned. Those stems don't slide out like cartridges.
  • You certainly need to first turn the stem fully "on" (after turning off the water supply!) I'm not sure that turning the stem further will remove the whole valve though.
    – Armand
    Aug 16, 2023 at 16:13
