Really simple question.
I have a mix of 1/2” mold-resistant and standard drywall sheets remaining on a remodel. Is there any silly reason why I might not want to mix the two together where I don’t need mold-resistant? Is there some odd taping or finishing concern that can pop up?
Surface will be textured with a hopper to match existing then painted.
I've done that with left over drywall. I tried to use the pieces in a closet.
If textured, I have found no difference in the final finish.
Go for it.
  • Thanks - new to drywall, so I didn’t want to find out after the fact that you don’t want to do that for some strange reason!
    – Richard
    Aug 15, 2023 at 22:57
  • In bathrooms, it is not uncommon in older homes to find the Moisture resistant right next to the standard drywall right outside a shower or tub area.
    – RMDman
    Aug 15, 2023 at 23:02
  • As long as they're the same thickness, no problem!
    – Huesmann
    Aug 16, 2023 at 12:34
