I'm going to use Set-Rite flange kit to bring up the height, but the instructions say to use a wax ring for cast iron or the included rubber gasket for metal. Not sure which method to use. My tubing is ABS, but the flange is metallic. Could this be a cast iron flange?
I did see a youtube video where the guy used the wax ring method even with a plastic flange, is that better than the flimsy rubber gasket?
