I bought a house a year ago that sits on a hill. The uphill side is on the ground. The downhill side sits on a carport that sits at the top of our driveway. The carport has a large opening (18'2" wide and 6"10 tall), and the carport interior itself is wide (about 21'). It is enclosed on 3 sides. I would like to add a garage door so I can store tools and bikes and similar in the main garage area.
Here is the problem: there is less than 1" of additional ceiling clearance above the opening of the garage. So, if I were to put in an overhead door, I would need to frame it down by at least 4" (depending on who you ask, it could be as high as 8-10"). That would limit the vehicles I could part in there (and, in some cases, mean that I can't stand up straight in my garage).
I started to look into horizontal open garage doors, specifically around-the-corner side-sliding garage doors, but the only ones I have been able to find are either: Available only in Europe/are incredibly expensive to import to the US
Commercial doors that may or may not be able to go around-the-corner and, for the ones that do, the hanging hardware hangs the door 7-8" from the ceiling, which would maybe be slightly better than reducing the height of the entire garage by that amount, but would will require that I frame the opening down further.
Have you run into good side-sliding door hardware options? I have enough depth to pull it around to the sidewall with room to spare. And I would be very happy to buy a standard door and turn it on its side, but I have had an impossible time finding the right hardware for a side-sliding system.
Any advice on how to overcome this issue without spending a ton or tearing down the carport and starting over, is more than welcome.
