I have a portable AC. For years, it worked as well as can be expected. Recently, it caused lights on the same (and only) circuit to flicker. The problem went away after turning it off, and came back after turning it back on.
I'm thinking about replacing the largest capacitor (which I assume is for the compressor) because it didn't start cooling when it should, and that seemed like the capacitor most likely to cause problems.
My bigger concern is with the lights flickering. They continued to flicker for a few minutes after unplugging the unit. Turning the lights off and on didn't fix it. They're LEDs, and those are finicky about voltage. I also heard an air purifier fan sound funny during the flickering. Could it be something else on the circuit trying to "catch up" after running on low voltage? The building is old and a lot of the wiring is knob and tube. Are there any wiring issues that could happen from high or wildly variable current draw that then go away a few minutes later?
