I have a bosch washing machine series 8 with IDOS system for 3 years. The IDOS pump for fabric softener is working properly, but the detergent pump is out of order. How should I replace that pump? What I have done: I removed the detergent drawer and after washing, I removed the upper compartment and found two pumps that have four crv 2.5 screws (five-bladed screw).
I removed the screws, but only got access to two gears. The pump motor is located inside the upper chamber and the cover of the upper chamber must be opened, but it seems as if the cap is completely pressed and stuck to the chamber. It does not have any screws. My problem was mentioned by someone else a few years ago in another forum, but no proper answer was given to it.
The price of the drawer is 160 euros on Amazon, but shipping it would be expensive for me and almost impossible. So if I can just change the pump motor, it will be great.
