What can I use to create the impression of an arch over my garage door?
    You would reduce the overhead clearance at the sides. Is that what you want? Or you could build up something that looks similar to the door panels (depending on your door construction) and attach it to the wall above the door.
    – Huesmann
    Commented Aug 10, 2023 at 13:48
  • Could you post an example and a photo of your current garage Commented Aug 10, 2023 at 14:20
    It's an interesting question, but a vague one. You'd typically make something like that, as variation in style and implementation would make it unsuited to mass production. I suggest revising to ask something more specific about your situation. I consider the question off topic as it is. We're not a discussion forum. Please see How to Ask and take the tour.
"false facade?" We'll let that pass. A simple approach would be to cut a curve on one side of a trim board. You could make the arch as curved as you want:
    The phrase isn't actually redundant, if that's what you were implying. It translates to "false face". A facade isn't necessarily false.
    Commented Aug 10, 2023 at 14:19
  • Not redundant, a double negative. A false facade of brick...would be real brick....no? Commented Aug 11, 2023 at 5:10
  • fascade actually has two meanings and Steve & @isherwood have each picked different ones. One is simply "the front of a building", the other implies a "false face". I'd agree that "false fascade" does feel quite redundant, but in many ways, it's simply being more precise.
    Commented Aug 12, 2023 at 13:36
