so we were having problems with a stripped wire that runs from the AC outside to the hvac inside so for a few days the ac did not work. We had someone come out and he ran a new wire but now the AC won't shut off unless we remove the thermostat from the wall. It's a vivint smart thermostat. Only 4 wires no c wire. When I look at the have wiring thought the guy did, he connected a C wire. Can anyone help? How am I supposed to fix that without spending more money.
    disconnect the Y wire from thermostat and see if that works. If it does you need new thermostat
    – Traveler
    Aug 5, 2023 at 19:09
    Turn the switch on the furnace off. Take the top cover off. Take the lower cover off. Take a picture of the wires where they go on the circuit board, with it clear which wires go to the outside, and which ones go to the t-stat inside. Then put it all back together and turn the switch back on so it at least works for now.
    – Mazura
    Aug 5, 2023 at 22:41
  • I would expect the person that ran the wire to warrant the work.
    – Gil
    Aug 6, 2023 at 3:47
