I have seen wasps going up into my soffit. I want to take down my soffit, deal with any nests, and replace the soffit. Presumably, I'll add some wire mesh and caulk where necessary to seal any gaps to prevent future infestations.
My problem is that I have gutter in front of the fascia, and drip edge leading into the gutter. Do I have to remove the drip edge and the gutter to deal with this? If so, that is a much bigger job than I am willing to take on. Is there an easier way to remove it? It appears to be attached with roofing nails in every other groove at the front edge.
