I have an existing GFCI outlet under my sink dedicated to my dishwasher. I want to add an outlet next to the GFCI that can be controlled by a switch for my garbage disposal. There is 14/2 wire running into the receptacle with the GFCI. I pulled some 14/3 from the switch to the same receptacle to control the new outlet. I attached a picture to give an idea of what I'm talking about. The power coming in will connect to the line side of the GFCI. The run the neutral and hot out of the load side to the outlet. I'm not sure how to incorporate the switch. I would appreciate any guidance.
Why use a receptacle at all? Why not hard-wire the disposal? Then you have load hot go to black up to switch, load neutral white split to go to switch (where it will be capped unused, but newer code requires it to be present) and the disposal, switched hot red from switch to disposal and ground everywhere (of course). If the existing GFCI box has enough space then you don't even need a new box (which otherwise you will need to mount the new receptacle).– manassehkatz-Moving 2 CodidactCommented Aug 2, 2023 at 18:30
1FWIW I put an outlet and a plug on my garbage disposal for those gross but necessary times I had to stick my hand in the disposal to get something out that shouldn't have been in it. 'Twas a good feeling of safety knowing I had the disposal plug in one hand while the other was going in for the dive, and it couldn't turn on because it was unplugged, and no one could flip a switch or a breaker and buzz my hand.– TriplefaultCommented Aug 2, 2023 at 18:41
@Triplefault Totally understood. But a bonus of the GFCI protection (required now, not when I redid my kitchen 20+ years ago) is that if the GFCI is nearby (as this one is), you can: Push the TEST button the GFCI; verify with the switch that the disposal is indeed truly unpowered (and then turn the switch off anyway) and the only way the disposal could then turn on is if somebody both pressed the GFCI reset and turned on the switch.– manassehkatz-Moving 2 CodidactCommented Aug 2, 2023 at 19:10
@manassehkatz-Moving2Codidact, do these work differently in US? Down under they flip the RCDs (their name here) on that circuit at the board as well, because i think they just short the ground to neutral. Also, it is a requirement to have an override switch above the bench.– Rohit GuptaCommented Aug 2, 2023 at 20:19
Just liked the idea of having the other outlet controlled by the switch. The disposal already has a cord attached so I figured just wiring the outlet to work off the switch would be the easiest solution.– NYDIYerCommented Aug 2, 2023 at 21:01
1 Answer
In the simplest solution, a cable goes from the GFCI to the switch box, and another from the switch box to the outlet. At the switch box, white goes to white, ground to ground, and one black goes to each of the switch terminals.
If this is impractical, the wiring can go from GFCI to outlet box, and a second cable goes from outlet box to the switch. This is a bit more complicated and I'm not up for describing it again right now; search past answers for "switch loop".
