Prior to the ubiquity of LED bulbs, I installed a Lutron dimmable light switch in a bedroom that runs a wall socket.
With incandescent bulbs, everything worked great, but when I switched out all of the bulbs for dimmable LEDs (Cree), the bulbs would not turn off all of the way. They would only go to their (assuming) minimum brightness.
I put one incandescent back into the 2 lamp, 4 bulb configuration circuit. With the load an incandescent bulb has by virtue, all the bulbs turn off all of the way. Proving the theory correct, when that incandescent bulb died, the LEDs turned back on to their minimum brightness. Replacing the incandescent with another I had leftover and was holding onto for this very purpose, the issue was once again resolved.
I would like to know if there is another way for me to achieve this without an incandescent bulb on the circuit? Is there something that provides a minimum load that I can add to the circuit (pass-through) that will provide this minimum load?
For those concerned about the dimmer on an outlet, your concerns are founded and understood. Having said that, it's marked as dimmer, it's behind a nightstand, generally inaccessible, and fully occupied by the lighting. I will swap out the dimmer if I ever move. But, whilst I own the property, it'll be okay. :)
