I'm in the middle of a remodel of my downstairs master bath. There has always been a squeak in the floors and I knew when I started this project that was something I definitely had to fix. There is one particular piece of subfloor that when I put a foot on each side of joist and move back and forth, I get a terrible squeak. That piece of subfloor goes a couple of feet from a wall and the next piece goes into a closet and from inside the closet, I can make the same thing happen. So basically these two sections are the main culprits.
Originally, it was nailed and glued, then after the fact it was screwed (a matter of fact the framer made an extra point about it saying he was going to make sure that the floor would never squeak). I went through and put in screws -- the more screws I put in, the more it didn't seem to change it. Now I'm about maybe screws 4" apart all along the joists.
Next I read shimming might help from underneath. Having someone squeak the floor above, I tried to wedge shims underneath with wood glue. The glue that was already there made that difficult and I tried using a mulitool tool to work out some of the original glue so I could shim. I tried a few places but I didn't get any improvement with that either.
What do I try next? I had two directions I was thinking -- one is to just cut out the subfloor on both sides and replace or run support blocking across each joist. Which is the mostly likely to fix this or even worse, if I'm having this much of a problem is it a sign of something else? It looks like a legal span so I don't think its a problem there but I'm not sure.
